2000 kx125 help!!!???
Hi guys I need of help with my current 2000 kx125 project. I’ve recently picked up 2009 rmz250 forks to convert over to something a bit heavier oppose to the oem forks. But in the process I’ve comes to a stand still in that when I put the lower half of my triple tree into the neck it does not come up far enough with the upper bearing in to get a thread on the nut that goes on top of the upper bearing. I need of some help or possible alternative routes to other triple clamps or machining of the clamps. Can provide photos if needed.
