Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
2004 kfx700 miss fire/back fire
Old Oct 13, 2013 | 08:20 PM
rob114's Avatar
Default 2004 kfx700 miss fire/back fire
I bought this quad about two weeks ago and tore it down and found a few problems fist thing it ben rolled. all that stuff has ben fixed but,this it only dos it at iddle and through low rpm it seems like a miss fire but with the air box open sounds like a back fire through carb from cylinder #1.could it be a vacuum leak or timing or valves?
Old Oct 13, 2013 | 08:24 PM
or a loose plug wire? You mentioned that it was rolled. Things come loose
Old Oct 13, 2013 | 08:39 PM
rob114's Avatar
i replaced the plugs and i thing that wire did separated from the metal connector.and also iddles vary low and iddle adjuster is turd all the way
chainslack
Apr 2, 2013 04:25 PM
Reaper700
Mar 22, 2011 08:30 PM
GarretsonG
Dec 22, 2010 08:12 PM
Finger Mullet
Nov 26, 2007 03:18 PM
Blackkawi400
Mar 31, 2006 06:31 AM
