Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
1995 bayou 300
Old Jun 24, 2008 | 01:16 AM
russm03's Avatar
Default 1995 bayou 300
working on friends bayou 300 4x4. when it first started, if you turned on lights it would die. eventually would not run. he removed all wiring, no bare spots, or broken wires. Then new cdi and regulator. by this time it had sat up for a year. would not crank. took carb off cleaned good, removed all jets, blew through all with carb cleaner 3 times, 3cans carb cleaner. now it will idle, but dies when you give it gas. timing looks right, valves adjusted correctly. any ideas? I am at the end of my rope with this thing.[&:][:@][:'(][sm=chairshot.gif]
Old Jul 2, 2008 | 10:39 PM
russm03's Avatar
Default RE: 1995 bayou 300
I beleive it might be in the wiring, should the black wire with yellow stripe coming out of cditie in to lights?
MMarty
Apr 6, 2007 03:16 AM
MMarty
Apr 5, 2007 02:53 AM
lg_rebel
Dec 25, 2006 10:49 PM
acerulz
Mar 28, 2006 03:57 AM
acerulz
Mar 28, 2006 03:56 AM
