02' prairie 360 4x4 problem
my cousin has a 02 prairie 360 4x4 which he knows nothing about the check belt light is on blinking (7times slowly then 5 fast)so i took the cover off the belt looked fine i read on another site mentioned in other post to look for a switch and switch grey toblack black to ect. i did not find any such thing any help? also the 4x4 light stays on could this be caused by a junk battery? and 1 last one it will not run off of choke i thinking bad gas b/c he has no idea when the last time fresh gas has been put in. any help would be awsome thank you in advance
I can't comment on the belt, but the check engine light has nothing to do with the battery, and the fact that the bike runs only with the choke out probably means that there is a jet plugged. Its time to pull the carb and do a little house cleaning. Unless that thing is fuel injected, I'm not sure about that.
Hey Brian, check out this link, I did a Google search for Kawasaki Prairie Codes, and this was the first site that came up in the search. Good old Google.
http://www.cyclepedia.com/kawasaki-atv-belt-reset/
Whoops I read down the page and realized that they are trying to sell you something, my bad, there has to be a free answer out there somewhere.
thanks for the replys i'll check the jets tonight if i have time ive got racecars to work on aswell i guess it does make sense b/c it does seem to be kinda slow it revs out good/smooth but only does maybe 20-25 mph (not sure if it's in 2wd or 4) orare those speeds normal for this quad?
