SOLVED! Mule 4010 Fuel Injection Idle problems - running rich
Old Nov 6, 2018 | 08:48 PM
Snakebit12's Avatar
Talking
Originally Posted by locorob
So I finally bit the dust and disconnected the crankcase breather tube on the ol' mule. It started running better almost immediately. It got better the longer it ran and I didn't even clean the throttle body. By the way I did check with the local dealership where I bought it from, they ran the vin number and came up with no recall on the 2012 model throttle body. So here's where I'm at, I routed the breather tube back around behind the fuel rail shortened it so that it turned downwards so I didn't get any water in the crankcase when I washed the engine or drove it thru a large puddle. Now comes the problem, after driving it full throttle down the road the breather tube started to blow oil onto the engine block. So now I'm back to the drawing board, there has got to be a better way to vent the crankcase than back thru the throttle body gumming up the butterfly valves. I thought about going to the local auto parts store and trying to find an old style breather cap that would go over the end of the hose and routing the tube to a different location. Anybody got any ideals? I tried to attach a picture of the current setup but it didn't work. As many people on the forum here with the same problem i figured maybe someone has come up with something I haven't thought of yet.
I am not sure that this is helpful but...
Before I discovered the recall, I disconnected the breather tube, inserted a cheap cloth filter in the open tube opening and taped it facing downward to the frame. I effectively vented the crankcase to the atmosphere (albeit with a filter to minimize my guilty feelings). I plugged the open hole in the throttle body with a rubber radiator plug. I ran this way for a few months without any issues before I had the throttle body replaced. I did wash out the filter a time or two.
Cannot speak to the vacuum issue but can say that I was getting fuel in the oil in the original configuration of routing the crankcase vapors into the throttle body. What a terrible engineering design.
Old Nov 7, 2018 | 01:31 PM
locorob's Avatar
Default 2012 Kawasaki mule 4010 throttle body
First off, thanks for the responses. I posted pictures in the gallery on my second attempt. I went to O'Reilly 's auto parts and gathered my supplies. I got three feet of 3/8" i.d. Hose, should have been half inch cause it would not go over the nipple on the crankcase so I had to use a short piece of the original hose with a 3/8'' barbed nipple to connect the two. I then routed the hose along the roll cage bar to the left side where I turned it upwards a bit so any oil that entered the breather tube could drain back into the crankcase. On the end of the hose i bought a breather cap from O'Reilly. It's part number elderbrock 43510. It takes another 3/8'' barbed nipple to connect to the hose.
I like the idea that OIIIO suggested with the catch can it would look more professional. I did notice after i started the engine vapors were coming out of the breather cap so i know its venting crankcase pressure without vacuum. My only concern in venting crankcase fumes back into the throttle body by any means is going to lead back to the original problem of the engine running to rich again. Thats just my thought. OIIIO, let me know if you have any luck with the catch can setup. As far as gas in the oil i haven't experienced that yet but I'll keep an eye on it, thanks.
I agree snakebit12 it was a poor design on kawasaki's part.
11/20/2018
I posted an update on this topic but it said it had to be reviewed by (a)the moderator before it could be viewed. Maybe it will show up eventually. It didn't turn out well.
01/25/2019
Update on my mule. I followed snakebit 's advice and took it to the dealer. They contacted Kawasaki and they agreed to pay for the new breather kit and throttle body. I was out the charge for adjusting the valves. Bumped the compression up from the low 190's to 200 psi. Cost was $110 and a month without the mule. Been driving the fool out of it since and it still runs as good as new. Thanks snakebit12!
Old Mar 22, 2019 | 05:12 PM
donk1956's Avatar
Default 2013 4010 Mule idle problems
I have had the same problem with mine. Carried it to dealer three time for it only to not last very long before the idle starts increasing and running rough. When it does this and in Low it is hard to go back to neutral and soot in exhaust pipe . The TB and vent line was upgraded the first trip to dealer. They suggested running a fuel additive but with no cure. I am going to try the disconnecting the crankcase hose and running it to the outside of engine. Thanks for all the insight.
Old Apr 4, 2022 | 06:58 PM
Doesimprove's Avatar
Default I did exactly this disconnect the vent hose , and it runs great , I
Originally Posted by Snakebit12
No pictures but I do have a video of the repair work...Not sure how to attach it? Edit: The site has a 5 MB limit on file size - my movie is 300 MB.
In any event, this whole issue has become moot from my perspective:
I found that this "cleaning" of the throttle body, while temporarily effective, would last about 6-8 weeks...and then I'd have to do it again. One day, while at my Kawasaki dealer picking up an oil filter, I asked the service manager "What solvent do you recommend for my bi-monthly throttle body cleaning?"
He replied "Why on earth are you cleaning your throttle body every 2 months?". When I explained the issue, he said "There is a RECALL on the throttle body. Bring it in and we'll install a new one...no charge".
When asked why didn't I get a letter on this recall, he responded "Not everyone had problems".
I got a new throttle body and intake and all it cost me was gas money.
My final question was why this problem had happened. He replied "The routing of the crankcase vapors into the throttle body gummed everything up".
So...my advice...if you are having problems, call your dealer about the recall. If not having problems (yet), unplug the crankcase vent hose from the side of the throttle body and plug the exposed port. Just let the crankcase vent to the atmosphere.
i I did exactly this , disconnect hose and it runs great , i’m going to get an oil catch can and hook it up to the crank case vent hose Thanks for the informationThanks for the information
Old Apr 5, 2022 | 01:52 PM
JJD's Avatar
JJD
I tried this fix and it did not work.
I thought this was the issue too, so I got some rubber fuel line and ran the hose off of the crankcase port and connected an in line PCV valve to it so that crank case presser could escape, but it would not allow outside air to enter if no pressure was being released. Plugged the connection port on the throttle body pipe.
It might have bought me an extra week, before having to clean it again.
Not the fix I was hoping for.
Old Apr 7, 2022 | 11:04 PM
Snakebit12's Avatar
As a follow-up on my situation...
Following 4-5 years to trouble-free operation after the TB/Breather replacement, I recently took my 4010 in to address another (supposedly unrelated) issue.
The engine would start and idle all day long. However, it would consistently die when you took your foot off the gas...especially on a hill. I suspected the fuel pump.
When I brought it in, my dealer told me that the TB/Breather was "treating the symptom" but not the cause. Not entirely sure about that as routing crankcase vapors into a sensitive TB seemed like a pretty bad idea to me. Anyway, he stated that Kawasaki has continued to have problems with these engines and that the real "culprit" was the ECM module which was causing my current issues.
Like with the TB & Breather, he replaced the ECM free of charge and the Mule is once again running like a top.
We love our 4010 Trans and consider it the most valuable piece of equipment on our 100-acre farm. The ability to fold down the 2nd bench seat to increase bed capacity isn't something that I can recall seeing anywhere else. And my dealer has certainly taken good care of me.
But I do find these engineering issues concerning... and would probably at least consider other manufacturers if we ever decided to expand the fleet.
Old Apr 8, 2022 | 12:48 PM
JJD's Avatar
JJD
Interesting to know, thanks for the update.
Old Aug 26, 2022 | 11:20 PM
  #28
drivfour's Avatar
so you took a 12 year old mule to dealer and they fixed for free?
Old Aug 27, 2022 | 12:19 AM
  #29
Azul's Avatar
I am interested, also. I had a '88 Mustang that the Ford dealership repainted for free do to a recall, may be the case here.
Old Aug 27, 2022 | 11:56 AM
  #30
Snakebit12's Avatar
My mule is a 2012 (earlier typo) so it is technically 10 yo.
But, yes, the dealer (Valley Kawasaki in Harrisonburg VA) installed a new TB in 2014 and a new ECM this spring at no charge.
