Our 3010 Mule will not run properly
Old Jun 30, 2011 | 01:25 PM
Jenny Wren's Avatar
Default Our 3010 Mule will not run properly
We have changed the spark plugs, oil filter, and fuel filter. We disconnected the hose from the carb to the fuel pump. The pump is pumping gas. We ran a wire from the battery to the fuel pump. It clicks and sparks. It still will not start. The ironic thing is that we filled our Mule and our mower up last weekend with gas bought at the same service station. Our mower is not running either. They both are doing the same thing. They just shut off while you are driving them. We did put some gas in a jar to see if there is any water in it. Nothing. We are lost. Anyone else have this problem? If so, can you give me any insight? Thank you.
Jenny Wren's Avatar
BTW, its a 2007 with 320 hrs.
Old Jun 30, 2011 | 03:07 PM
Jenny Wren's Avatar
Seems from reading previous posts, this is a very common problem with the Mules. The bad thing too is that not one person posts back to let anyone know what the problem was. I also was reading about the loud clanking noise when the machine disengages from 4 wheel drive back to 2 wheel drive. Ours has done that since it was new. Im starting to think that we have a lemon on our hands. I dunno.
Old Jul 13, 2011 | 06:10 AM
Emma121's Avatar
*All ***** kits Include seals and bearings for one axle. *Kit will only fit stock bearing carriers.
Uyless1
Jun 9, 2019 04:25 PM
chromedome
Feb 23, 2017 01:38 AM
Jenny Wren
Aug 31, 2011 06:41 PM
Older Not Wiser
Aug 4, 2009 10:27 PM
rcmch0829
Jan 8, 2007 07:14 AM
