Mule not starting
Old Nov 7, 2005 | 08:47 PM
joshb's Avatar
Default Mule not starting
I have a Mule 550. It ran out of gas. Filled the tank and it ran briefly, died and won't start. I have a spark. Any ideas?
Old Nov 7, 2005 | 09:04 PM
srobak's Avatar
Default RE: Mule not starting
Fried fuelo pump when it ran dry?
Old Nov 8, 2005 | 11:00 PM
joshb's Avatar
Thanks. How do I go about testing the fuel pump?
Old Sep 10, 2007 | 12:43 AM
KLX450R's Avatar
you can pull the line exiting the pump going to the carburetor and turn the motor over with the key and fuel should pulse out of the line. It won't be a steady stream as with an electric pump. It is hardly likely that running it out of fuel killed the pump. My best guess is that you got a piece of trash in the carburetor jetting or sucked up a bit of water from the very bottom of the tank. Try draining the carb bowl with the small screw entering the side of the carb bowl and let it drain out. Then turn the mule over several times to refill the bowl granted the pump is working. Then full choke, pat the accelerator while turning the mule over, and it should start up. If not I would try a new spark plug. Sometimes they will fire outside the motor but under compression they are weaker and partially fouled.
Hope this helps,
Jody
Shadygrady
Oct 9, 2015 12:48 AM
bill2014
Mar 16, 2015 10:43 PM
kketch
Sep 25, 2014 10:49 PM
garyk
Oct 7, 2012 03:43 PM
