Mule flooding problems
Old 11-26-2015, 05:41 AM
Bodine's Avatar
Default Mule flooding problems
If you have a Kawasaki mule that as soon as you turn on the key gas pours out of the carb. before replacing float and needle check the overflow tube and screw on plate where it attaches to the carb on top between the cooler T fitting and fuel inlet line. the bent metal tube. ( more like a kink ) can be come clogged with dirt or bad dried gas and become clogged which doesn't allow air to escape the carb bowl and forces the float down and gas into the carb throats
dbrown40
11-03-2013 09:46 PM
dan888
01-09-2009 02:01 PM
robmac
05-03-2007 06:04 PM
deejay1272
07-31-2005 04:54 AM
Quick Reply: Mule flooding problems
