mule 1000 fuel issues
Old Oct 19, 2015 | 03:06 AM
thetucks's Avatar
Default mule 1000 fuel issues
Im new to the forum and need a little help. I just bought a kawasaki mule 1000 from a friend that will not start without starting fluid. I have cleaned the carbs and they look good. the fuel pump is the manual kind that uses vaccum to pump it. once running it will pump fuel out but wont when trying to start it. any ideas? thanks
Old Oct 24, 2015 | 12:32 AM
CrashWrench4010's Avatar
Hi ,
Check the Fuel tank vent / Hoses .
Check the Hose From the Crankcase To the Fuel Pump .
If These are Ok, Change The Fuel Pump Itself .
The " Ethanol " In The Gasoline Eats / Screws up EVERYTHING !!!!!!!!!!
Try this, Post What You Find ......
Hope this Helps ,,
Later,
Mark K.
Nastymonte
Jun 13, 2014 03:02 AM
waystro
Jun 13, 2014 02:51 AM
bill2014
May 14, 2014 01:31 AM
calchef
May 16, 2013 03:26 AM
