KAF 300-C4 compression issues
Measured compression is 75psi. Book says 118-178 psi.
New carb, air filter,etc. Engine will idle for days but go out and drive it and it will miss in the midrange, run fine at top end and foul a new plug within 15 minutes mostly when driven in mid range. Fouling is fuel not oil.
Is this all compression issues as this system has no adjustment for rich/lean issues?
Help someone😩
Coondoggy
Help someone😩
Coondoggy
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
