Front end issue
Old May 20, 2019 | 02:32 AM
Dave40102012's Avatar
Default Front end issue
I have a 4010 mule trans I recently changed the front wheel bearing and axles after Changing I noticed the machine pulls to the left hard when in four wheel drive and only in four wheel drive is there something I did wrong or just adjust on the steering linkage?
Old Jun 10, 2019 | 01:31 AM
CrashWrench4010's Avatar
Hi,
You Might Have to Pull Off The Front Brake Drums Again .
Check for The a "" SHIM "" In Between The Front Axle Bearing ( out board ) To the Brake Drum . Next ( Sorry For This ) Did You Use A IMPACT GUN ???? If So ,, You Have Crushed the Front Wheel Bearings ….
The Proper Torque Is A Must !
Check the Front Brake Wheel Cylinders . They Are Self Adjusting ( The Adjuster Is part of the Piston Assembly > Internal < . Greased the Dust / Dirt Seal To The Brake Drum ?
Check the Front Differential . Possible that the " Snap - Ring " Has Come out Of Place . This Holds The Inner Stub Axle To the Diff. Bearing cap . The Inner Axle Can Slide Out Of The Drive Splines If It Was " Forced In Place " The Limited Slip Clutch Pack ( Inside the Front Diff. ) CAN Break !
Hope This Helps .
later,
Mark
Tom Colvin
Jun 10, 2019 01:20 PM
Akmule
Jun 12, 2018 05:29 PM
srsu
May 14, 2014 06:29 PM
EMS_0525
Mar 25, 2010 10:56 AM
gas_sippin_Kawi
Ninja 500R
Oct 25, 2006 08:30 PM
