Better Battery for 3010 Trans Mule
The batteries for the Mule suck. Too small, not enough power, small poles, lose a charge in cold weather, and play out in a year or less.
Has anybody replaced these junkie things with something better, and if so, what did you use specifically? Thanks |
Battery care
Hi,
I Have Been Using the NAPA Auto Parts "Napa Gold " Series batteries . Part # 7526R / O.E._code- b.i.c. NO:26R ( The " R " means Reversed battery posts ) . It is A " top post " , Same Dimension As the Factory battery. Higher Cranking Amps_ 540CCA , Sealed/ Maintenance free ..... Any Battery Allowed to set unused for A long Period of Time will go Flat/dead. Alternator /Charging system/ Cables/ Ground Connections OK/Clean ?? Alternator/ Water Pump Belt Tight ??? Recommend ; A battery cut-Off Switch ( Any Accessory , Alternator will draw power ) With the engine off . A Trickle Charger / Battery Maintainer ( IE: Battery TEnder ) Will Greatly increase The Life Of it. Using a Winch Or High powered accessories, boom Box Radios ,,, Will Tear Up a Battery ( A standard Battery ) In A Short Time . Best Possible Solution ;;; Dual Battery Setup :: One Standard Battery- ( For Starting, O.E. equipment/ Lights) ,,, 2ND Battery Would Be a " DEEP Cycle" Type ( Trolling Motor / Boat ) This would run all aftermarket Accessories :) . To Charge the Two batteries ,, A " Battery Isolator Kit " Would be Installed Between the Alternator and Two Batteries ... The First Batt. (primary) is for starting, The Second Batt. ( Secondary ) for Winch/ Aftermarket Accessories . Hope This Helps. Later, Mark |
