2016 MULE PRO-FXT™ EPS Fueling Issues
Old Apr 18, 2025 | 03:02 PM
GLF2025's Avatar
Post 2016 MULE PRO-FXT™ EPS Fueling Issues
Hello All,
Recently I have been tasked with diagnosing an issue with our 2016 Mule. The issues arising seem to contradict one another. Several drivers are reporting that once the unit gets up to operating temp it tends to stall out and bog down to the point it can't be moved. I am aware of the common issues people report with the fuel pump, so I will likely check it out regardless to be safe. However, upon initial inspection, I've found the exact opposite issue. I allow the Mule to get up to operating temp but the idle is very high and it takes off at the slightest touch of the pedal. No work has been completed on the fuel system as of late, including the carb and fuel pump. Considering these problems seem to be at odds I'm curious if anybody is aware of an issue that could link the two to a common problem?
Thanks for any advice!
blackswamp
May 10, 2023 11:05 PM
Bob Johnson
Apr 28, 2021 11:19 AM
russgoebel
Jul 17, 2020 04:47 PM
Adam$77
Oct 20, 2019 10:01 PM
Rutherford
Jan 22, 2016 12:39 AM
