2013 Mule 4010 Diesel throttle stuck
Old Mar 14, 2019 | 11:54 PM
Solidrockranch00@yahoo.com's Avatar
Default 2013 Mule 4010 Diesel throttle stuck
i have a 4010 diesel 2013 that the throttle is stuck at about half to three quarter. Any idea on fixing this problem?
Old Mar 24, 2019 | 10:58 AM
bpmule's Avatar
Tilt the bed and have somebody move the throttle pedal. Examine the movement where the throttle cable moves the lever on the fuel pump at the engine.
You need to determine if the issue is either:-
1. At the pedal.
2. In the cable.
3. At the pump.
Once determined somebody may be able to help you.
Old Jun 20, 2023 | 07:53 PM
Superglide7374's Avatar
Default Stuck throttle
1. At the pedal.
2. In the cable.
3. At the pump.
Have similar problem. 2013 Trans Mule 4x4 Diesel throttle won’t return to idle position when accelerator depressed. Not stuck, just won’t return. Looked at exploded views, can’t tell if there is a return spring on lever by injection pump.
thoumitch
Mar 21, 2019 03:21 PM
thoumitch
Mar 21, 2019 03:16 PM
studebaker53
Jan 23, 2019 12:21 AM
Jmill857
Aug 8, 2018 11:07 PM
muleuser
Mar 2, 2014 05:24 PM
