1993 Mule 2520 What is this Part?
Old 06-27-2017, 07:56 PM
samb's Avatar
Default 1993 Mule 2520 What is this Part?
I am trying to fix up a Mule that my boss owns. I took some things apart about a month ago, and finally got around to fixing the original issue, which was the gear shift splined shaft had broken off. With that fixed, I began to re-assemble, but for the life of me I can't figure out the purpose, let alone the assembly of this part:
If the pic doesn't show, here is a link to it:
https://drive.google.com/file/d/0B7O...ew?usp=sharing
What does this bracket do? what does it connect to? Does anyone have a picture or video of this part installed and working?
Best,
Sam
Old 06-30-2017, 05:51 AM
samb's Avatar
Can anyone help? I feel like anyone who has been wrenching on these should know... I'm just new to these and I can't find an owners manual anywhere.
Old 06-30-2017, 03:18 PM
Anthony LaGrasta's Avatar
it's either your clutch or throttle cable.
Old 07-16-2017, 06:37 PM
CrashWrench4010's Avatar
Smile Finding " What Parts"
Hi Samb,
If You push / pull / Levers / Step On the gas Pedal ,, What Cable Moves ???
The Big Cable under Your Hand ( in the Pic. ) looks like The forward / Neutral / Reverse
Shifter Cable . The " Plate " You Are Holding , maybe The Engine Speed /
Governor Plate Which Mounts On the Engine .
Can You Send me a PM.
I May have A Manual At Work For This Mule ????
DGMOORE78
04-28-2017 01:04 PM
C. Amick
07-05-2014 12:25 AM
cqsmrtazz
12-02-2013 07:57 PM
Vic Williams
10-10-2012 08:00 PM
Quick Reply: 1993 Mule 2520 What is this Part?
