Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
ts 650 erratic running condition
Old 08-04-2009, 05:31 AM
Rort's Avatar
Cool ts 650 erratic running condition
Hi guys,hope someone can give me a little input. Just bought a 95 ts 650, it was runnng rough, I adjusted the air/mixture needle to about 1.5 turns out, and put in new spark plugs. Ran great for first 2 hours of use, then refilled tank 50:1, drove it for 20-30 minutes and started bogging down and shutting off, let it sit for ten minutes and it restarts and rides fine for a couple minutes, this problem is ongoing. When it dies i have problems restarting and sometimes I just hear starter relay clicking. This happens right after it dies out. Hope someone can give me some suggestions on this problem. Thanks Ro
Old 08-05-2009, 08:17 PM
lambo2009's Avatar
Hi there check your spark as soon as it shuts down on your ride if no spark it sounds like your coil is braking down when it heats up try this may help
Old 08-12-2009, 03:51 AM
Rort's Avatar
Thanks for the input, last time out I leaned out the mixture and ran it 2-3 hours with no problems, but then the problem started again, seems to happen when I refill the gas, I cut off the oil injection and pre mix. I will check the spark when problem shows up, any idea what the factory idle air mixture adjustment is, I have it around 1 1/2 turns out, it idles real good and has power.
Beasty
11-02-2012 01:29 AM
greenmachine
12-11-2009 11:36 AM
stevetro
09-02-2009 04:19 PM
badvwg60
Ninja ZX-9R
12-12-2006 05:00 AM
Jacks Dad
09-23-2006 11:25 PM
Quick Reply: ts 650 erratic running condition
