Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
how does water get in the crank?
Old Jul 30, 2007 | 02:03 AM
89standup's Avatar
Default how does water get in the crank?
How is water getting in the crankcase on 1989 650 stand up?
also how do you get it out?
Old Jul 30, 2007 | 02:33 AM
JSTER's Avatar
Default RE: how does water get in the crank?
You have a water drain valve if a block off plate isn't already installed that could let water in if the seal is bad. There would have to be a fair amount of water in your engine compartment. The unit is below the starter. As far as getting the water out you can remove the spark plugs and crank the engine over with your fingertips in the holes or invert the ski and let the water drain. After the water is out I would spray some WD40 into the spark plug holes. If you don't already have a block off plate installed get one.
Old Jul 30, 2007 | 11:46 PM
89standup's Avatar
Thank you.
Is the block plate an aftermarket thing, and what does it do??
Old Jul 31, 2007 | 12:36 AM
JSTER's Avatar
Yes. You can find them on ebay pretty cheap. The water drain valve has a habit of failure which can cause the problem you have but also if not seated properly can cause piston seizure due to a lean fuel/air mixture.
Old Jul 31, 2007 | 12:45 AM
JSTER's Avatar
Sorry. You asked what it does. It's supposed to drain water that has enters your engine by pulling up on the **** that's at the end of the cable which operates the valve. After a while the unit will not seal properly.
Old Jul 31, 2007 | 12:58 AM
JSTER's Avatar
I didn't read your post properly. The block off plate covers the sealing surfaces after you remove the water drain valve.
JBP1
May 2, 2011 10:14 PM
cjcrashesalot
Dec 28, 2009 12:57 AM
89standup
Aug 11, 2007 06:14 AM
Cold Iron
Jul 24, 2006 09:47 PM
