Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
97 ZXI 1100 sitting for 10 yrs on stand
Old Apr 23, 2011 | 08:25 PM
GoBolts's Avatar
Default 97 ZXI 1100 sitting for 10 yrs on stand
I'm finally getting back on my 97 ZXI 1100. Any recommendations on what I should do before I try starting it up. It was always hard to start out of the water, but in water it always started right up?
Old Apr 25, 2011 | 04:05 AM
Prom's Avatar
I always say to flush all your fluids, but not much in the ski but fuel and oil. Get the old fuel out change the oil and get new filters as well. Clean the carbs and inspect all the rubber hoses, seals, and other stuff for cracks or rotting. once everything is fresh and clean give her a go, good luck bruddah!
Old May 1, 2011 | 07:37 PM
JBP1's Avatar
also get some wd-40 or such and spray all moving joints, cables, etc
Old May 7, 2011 | 02:32 PM
GoBolts's Avatar
It was preserved really well when I last used it. It just doesnt want to cold start. IS there some thing that I can do" install a "bulb primer" or something...
Old May 8, 2011 | 05:39 AM
Prom's Avatar
Choke should be all you need, might want to clean the carbs if you havent already.
papasmurf745
Mar 30, 2009 01:44 PM
assurancegt
Dec 2, 2008 01:53 PM
kirbyr76
May 17, 2008 12:13 AM
caveman2207
Feb 9, 2008 01:53 PM
tbrane
Sep 14, 2007 01:59 PM
