Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
97 stx 900 oil light on pump or sending unit?
Old Sep 1, 2007 | 06:52 AM
Basser1's Avatar
Default 97 stx 900 oil light on pump or sending unit?
I have a 97 stx900 that has never had any problems as long as we owned it. Oil has always been kept full and on last trip oil light came on as we were putting it on the trailer. Is there a sending unit that could have failed or is the pump the most likely culprit here? Thanks in advance for any help you might be able to come up with!
Basser
Old Sep 10, 2007 | 01:05 AM
KLX450R's Avatar
Default RE: 97 stx 900 oil light on pump or sending unit?
No warnings are given on pump failures, unfortunately you will not know till too late. Good advise I have is if the ski is 8-10 years old. While having the sending unit on the oil tank replaced have the dealer replace the lines to the carbs from the pump with Kawasaki OEM lines. I have seen them break after several years and cause major engine problems. Run premixed fuelat 2 OZ of oil per gal of gas for first tank full after lines are replaced to avoid engine seizure. There will be some air in lines till engine has run for a bit.
Hope this helps,
Jody
Old Sep 15, 2007 | 02:58 AM
Basser1's Avatar
Thanks for the answer on the oil pump failure and the advice to change the lines to the carbs it was a big help
Basser
Old Sep 17, 2007 | 02:46 AM
KLX450R's Avatar
Your welcome! What are kawasaki fanatics for?
Old Jul 30, 2010 | 05:00 AM
some_change's Avatar
Default correct gas to oil ratio for 97 STX 900
I have just replaced the engine in my 97 STX 900, the replacement engine is used so no break-in needed. however I don't trust the oil pump so I want to pre-mix the gas. The service manual refers to a 50:1 ratio while testing the pump, would this also be the correct ratio if I'm not going to use the oil pump?
Any info would be greatly appreciated.
haz
Jan 21, 2015 02:12 AM
gutterboy2ca
Jun 5, 2012 11:15 PM
sean_james
Aug 16, 2009 09:45 PM
mc1457
Oct 11, 2008 07:51 PM
kawasaki272
Mar 11, 2007 05:18 AM
