Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
95 Kawi 750 SS Xi coil/ignition issues
Old Jun 19, 2012 | 02:19 AM
uncaged's Avatar
Default 95 Kawi 750 SS Xi coil/ignition issues
Hopefully, someone has an idea on this ignition problem.
So, I'm out on the lake tooling around and it starts losing power. Gets worse and worse and barely can get above idle. Checked it out and one plug isn't firing. Get it home and troubleshoot using the manual and coil tests bad. Tested the pickup coil and it was within specs. Replaced the coil with OEM Kawi unit. New plugs.
Ran good after replacement, after 2nd ride it craps out the same way again! Same cylinder!
Is there something up that I'm not catching? Can a brand new Kawi coil die so soon the exact same way??
Thanks for any help you can offer.
sabaugebenz
Oct 2, 2014 11:33 AM
Rutheford
Mar 9, 2013 08:50 PM
lashlarew
KX250 & KX250F
Jan 20, 2013 07:56 PM
horizonod
Nov 10, 2008 04:42 AM
trtle07
Jul 5, 2007 02:36 PM
