Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
94 650 TS Boggs on acceleration
Old Jul 4, 2006 | 08:34 AM
dlhglass70's Avatar
Default 94 650 TS Boggs on acceleration
My TS 650 runs fine most of the time when cruising, but when you first punch the throttle it tends to bogg down real bad and then catch up with itself and run fine did die twice giving it gas but starts right back up. PLease HELP
Old Jul 4, 2006 | 09:05 AM
BigRig18Wheeler's Avatar
Default RE: 94 650 TS Boggs on acceleration
Welcome to the forums man!!!
One trend we have noticed around here on the jet skis, is old fuel and plugs.... You might drain your fuel, put some good gas in there. And change the plugs....
I bet that will get her back to tip top shape. If you still have a prob after that, let us know...
Enjoy your stay!!
Old Jul 4, 2006 | 09:42 PM
dlhglass70's Avatar
I don't think the gas can be very old, I have been running them every weekend since April, and Iusually go through 2 tanks every weekend. I tried plugs as well with no change whatsoever, I was wondering if anybody knew how hard it was to rebuild the carb, or if that could even be the problem??
Old Jul 4, 2006 | 11:24 PM
Ya, if the fuel is good, and the plugs are good, then the culprit is probably the carb...the carb is pretty easy to clean... You will need maybe 3 or 4 cans of a good carb cleaner. You can take pics as you go along on disassembly, then if you get stuck somewhere, you can refer back to the pics as to re assembly. The carbs do get gummed up after a while, so a carb cleaning would not hurt at all.... With the cleaning of the carb, it is probably a good idea to go ahead and change the fuel filter also.....
I had a similar problem not real long ago on my bike, and it was dirty carbs....Cleaned them and she runs like a brand new one again.....
GL !!!
RXR5795
May 5, 2010 12:27 AM
molinaman98900stx
Apr 1, 2009 02:50 PM
giovanni67
Jul 20, 2008 11:36 PM
danriley50
May 13, 2007 05:35 PM
winterpop
Jul 4, 2006 07:44 AM
