Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
1995 750ss major driveshaft problems/how bad?
Old 07-22-2012, 04:03 PM
mckeddie's Avatar
Default 1995 750ss major driveshaft problems/how bad?
so the first time i took my 750 out, i noticed it had a terrible vibration at low rpm (terrible at idle), but smoothed right out when you gave it throttle. it powered up strong in the water though, so off we went. made it half way across the lake, hit a wake, and it died. fired right back up, took off fine, got it up to speed, hit another wake, and it died again. fired it back up, hit the throttle, revved but didn't go. revved it again, and nothing, so i shut it off. buddy that was with me on my other ski came over, hooked up a rope and started pulling it to shore, this was when we realized it was taking on water rapidly. by the time we go to shore, the hull was full. drug it up on a lift and drained the water out to assess the problem. found the coupling between the motor and the driveshaft was broken, driveshaft was bent, and seals at the rear of the shaft were broken. went to town, bought some expandable foam, filled the driveshaft tube with it, waited a couple of hours, and pulled the ski back across teh lake to the ramp and got it out to bring it home to fix it (it was at his lake house up on syracuse in indiana).
anyways, that's the back story as to my dilema. i'm new to jet skis, so am not sure where to start on this. i pumped water out of the motor already because it sucked some in, so motor is spinning freely again, but wont fire. i'm sure with the amount of water it took on, i need to drain the tank and put new fuel in. how do i go about pulling the driveshaft? does it come out the front or the back? im not sure of the technical terms for things, so if someone could tell me what they are, and what all i need to get, that would be great, here are a few pics of what i can tell i'm dealing with so far.
(in the frist pic, i tried cleaning some of the foam out of the was so its easier to see)
also on a side note, this is a pic of my intake, is this all there should be? or should there be a tube that runs up to the intake vent on the front?
thanks for any help, i appreciate it.
greg
hermie
07-09-2009 01:24 PM
sambeaux
06-22-2009 09:41 PM
gricey
03-27-2008 05:13 AM
markmeinteil
10-12-2007 07:52 PM
emery
08-15-2006 04:55 AM
Quick Reply: 1995 750ss major driveshaft problems/how bad?
