Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
1994 750 jet ski boggs and stalls in the water
Old Aug 10, 2005 | 04:25 AM
danriley50's Avatar
Default 1994 750 jet ski boggs and stalls in the water
I've seen this before with similar kawasaki jet skis, but I'm not sure what causes it. I can get the ski to rev-up fine out of the water but as soon as I go to ride it IN WATER, it only idles for about 20 seconds and eventually stalls. When I go to accelerate, it stalls. ???
Old Sep 1, 2006 | 07:42 AM
creeper's Avatar
Default RE: 1994 750 jet ski boggs and stalls in the water
I have a 84 Kaw 550 jet ski that does the same thing. I started it on my pickup and it had lots of power, and when I put it in my pond it was very doggy. Slow ride around the pond.
Old Sep 2, 2006 | 01:02 AM
kawman's Avatar
Any exhaust leaks??
Old Sep 20, 2006 | 11:16 PM
meangreenman's Avatar
Hello 750,
Have you fixed the problem yet? What is the compression reading on your engine? It seems your problem is related to either the engine or jet pump impeller/bearing, but not the carburetion, since it happens only when there is a load (water). How easy is it to turn the jet pump shaft?
Old May 13, 2007 | 05:35 PM
wakeboarder82420's Avatar
i had the same problem on my 04 750 XI.... it was the jet pump, easy to install just around $200 on ebay
gsrcivic9
Apr 12, 2011 02:04 AM
RXR5795
May 5, 2010 12:27 AM
molinaman98900stx
Apr 1, 2009 02:50 PM
rickmedina
Jun 10, 2006 05:41 AM
