zx6r f3 1997.
Old Sep 17, 2012 | 09:04 PM
wood1's Avatar
Default zx6r f3 1997.
carb problems i think
Old Sep 17, 2012 | 11:56 PM
ok, you got me. Welcome to KF and let us know how you may think that the carbs are causing you an issue.
Old Sep 18, 2012 | 09:27 PM
wood1's Avatar
Hi i run it on reserve an it sucked all the crap up out the tank an it started missing so i cleaned tank pipes carbs put new in line filter on it. It is running a bit better but it is still missing at low revs
Old Sep 19, 2012 | 01:45 AM
I would suggest cleaning those pilot jets again. (I take everything apart and soak the unit.) Either they were not soaked and blew out good enough or generally most people tend to forget that they are even there. So they do not take them out for cleaning.
Old Sep 21, 2012 | 04:20 PM
jeffzx9's Avatar
(....and don't try to shortcut the process by pouring a bottle of some caustic "drain cleaner" in your gas. Bad, bad, bad. Agree with Drag^--do it right.)
Old Sep 27, 2012 | 10:10 PM
wood1's Avatar
Hi do you need to balance the carbs if you take them off? cleaned them again today found water in the float cambers so drained tank but it still not running rite still missing but if you gun it, it dont miss till half way thro 3rd.
Old Sep 28, 2012 | 03:07 PM
jeffzx9's Avatar
Originally Posted by wood1
.....cleaned them again today found water in the float cambers.....
How did water get into your bowls when you just cleaned them a week ago?
Old Sep 28, 2012 | 03:33 PM
Tell us you didn't hose out the tank with water....
Old Sep 28, 2012 | 07:27 PM
wood1's Avatar
Ha ha no i didnt lol its been raining alot lately its holding water around the fual cap so every time i open it water is poring in. over flow pipe is blocked
Old Oct 17, 2012 | 01:57 AM
kinman's Avatar
i am looking at a brute force 750 a guy has for sale and every once and awhile the starter locks up and he has to push it and throw it in gear to get it unlocked. Just curious of what it could be before i purchase it
