zx6r f3 1997.
carb problems i think :(
carb problems i think :( |
Hi i run it on reserve an it sucked all the crap up out the tank an it started missing so i cleaned tank pipes carbs put new in line filter on it. It is running a bit better but it is still missing at low revs:confused:
I would suggest cleaning those pilot jets again. (I take everything apart and soak the unit.) Either they were not soaked and blew out good enough or generally most people tend to forget that they are even there. So they do not take them out for cleaning.
(....and don't try to shortcut the process by pouring a bottle of some caustic "drain cleaner" in your gas. Bad, bad, bad. Agree with Drag^--do it right.)
Hi do you need to balance the carbs if you take them off? cleaned them again today found water in the float cambers so drained tank but it still not running rite still missing but if you gun it, it dont miss till half way thro 3rd.
Originally Posted by wood1
(Post 482965)
.....cleaned them again today found water in the float cambers.....
How did water get into your bowls when you just cleaned them a week ago? |
Originally Posted by jeffzx9
(Post 483020)
:DHa ha no i didnt lol its been raining alot lately its holding water around the fual cap so every time i open it water is poring in. over flow pipe is blocked:D
i am looking at a brute force 750 a guy has for sale and every once and awhile the starter locks up and he has to push it and throw it in gear to get it unlocked. Just curious of what it could be before i purchase it
