White smoke
Old Dec 7, 2020 | 10:52 AM
tuleysr's Avatar
Default White smoke
I have a 2011 mule KAF400EBF. Bought it new. Ran good all these years until last February when it started blowing white smoke and lost power. Looked on the web and found out it was the carb causing it. Took it to a repair shop and they looked at it and put a new OEM carb on it for $350 including a tune up. The shop owner said that aftermarket carbs are not reliable and I should part with the $170 to get an OEM carb. Now it is December and it is blowing smoke again and has no power. Forget trying to get any warranty from the repair shop. Since it is not rocket science, I ordered a new aftermarket for $45 and am waiting for it to come in., I figure if the OEM only lasts nine months. why spend the extra money. Meantime, I pulled the carb, cleaned it and blew out the orfices with air to no effect. Has anyone experienced this problem and found out what is wrong with the carb? No oil or fuel in the airbox but am getting excessive fuel out the exhaust (can see it on the ground). For those who are not familiar, the mule is air cooled so comments about water are no help. New to the forum and appreciate any information.
Old Dec 27, 2020 | 10:56 PM
Redman James's Avatar
Agree on useing original card verses after market . Had problems with my carb replaced it with after market and with in few days same problem replaced again with after market and same issue . ended up takeing old carb a part repairing float , put my carb back on been running great last 3 months . also as you said noticed the black Residue in gas lines . I now keep stay build in my Gas . also changing out fuel lines to a better ethanol hose , thanks for the info on the electric fuel pump
crounsebd
Apr 6, 2021 02:30 PM
tuleysr
Dec 6, 2020 10:10 PM
psquared
Oct 26, 2017 07:50 PM
jpbpe
Oct 30, 2012 11:58 PM
witzode
May 26, 2007 03:05 PM
