White GOO??????
like what kind of problems? clogging? i guess this stuff isnt supposed to ever clog or whatever, anyway im taking the bike to my voc class tomorrow to put the pressure tester on it mr big thats a great idea, thanks!
ok found the problem, pretty much what it came down to was the bike sat for more than a year, actually more like 2, and with condensation and everything, moisture got in, the past couple days ive been really feedin it to her and it has coocked away most if not all the goo (moisture). i was so happy this morning when i saw that there wasnt any more in the oil!!!!
I'm a car mechanic, don't have much experience on bikes yet, but it's still an internal combustion engine, so I figure you can do the same thing we do with cars that have sat a while and collected condensation, which is run it hard so it all boils out of the oil. Best thing for cars is change the oil the drive em as much and as long as possible, would figure the same for a bike.
just an idea you could go get some uv dye and put some in with your coolant, coolant only. then run the bike for a bit. next drain the oil and use a uv light to check for the dye in your oil. that would tell you for sure if there is a coolant to oil problem such as a blown headgasket. good luck
deej
May 12, 2009 01:23 PM
volume@11
Jul 8, 2006 07:38 PM
