When KLX250 on stand and in gear, rides rough.
Old Jul 24, 2014 | 12:20 AM
Mossman's Avatar
Default When KLX250 on stand and in gear, rides rough.
Hey guys, had my 2012 KLX250s for about 2 months now. I had it up on a block and was adjusting/lubricating chain. Put it in gear and let it do it's thing but I noticed that it seemed to be jumpy and make some strange noises. Its not jumpy in any uniform manner but once in awhile it just seems to get rough and shake the entire bike and make some strange noise.
I took a video of it, here is the link:
Old Jul 24, 2014 | 12:36 AM
The jerkiness you may be experiencing is normal. There is no load on the drive line, the single tends to have inconsistency in smooth spinning due to nature of the single, causing constant variation in speed of the crank.
This, in turn will cause the sort of snatching of the drive line due to the clearances in the primary drive, the gear box, and the chain slack required. The back wheel will just plain not run smoothly. If you lightly held the rear brake to put a load on the drive line it would smooth out, although you might need a touch of throttle to keep from stalling it. That same thing is why there is a jerkiness when trying to do extremely slow maneuvers with the clutch engaged.
Four cylinders will smooth out with less ******, but still are not perfectly smooth.
I think that answers your question.
Old Jul 24, 2014 | 12:56 AM
Mossman's Avatar
That is great! Thanks so much.
Old Jul 24, 2014 | 02:07 AM
Makes lubing the chain a whole lot easier - doesn't it!
tom edison
Oct 31, 2011 09:36 AM
JAC
Jul 11, 2010 01:31 AM
Road Kill
May 25, 2009 03:35 PM
EMS_0525
Jun 29, 2008 06:16 PM
KINGVEGAS
Ninja 500R
Apr 25, 2007 07:03 PM
