WHEEL VIBRATION
Old Mar 23, 2006 | 06:44 PM
thatKAWIgirl's Avatar
Default WHEEL VIBRATION
I just got a new Dunlop Qualifier 180/55/17 on the rear. Front remains the Dunlop model prior to this one. I'm getting a weird vibration while riding. The faster I go, the stronger it gets. Is it because it's a new tire? Do i need to maybe let some air out? I checked the cotter pin and my chain seems ok. I can't see what's going on while I"m riding it so I'm just wondering what some common causes are so I know what route I want to take.
Thanks for your help!
Old Mar 23, 2006 | 07:00 PM
walight01's Avatar
Default RE: WHEEL VIBRATION
did you have it balanced? maybe the balance is off
Old Mar 23, 2006 | 07:30 PM
KevyzToy's Avatar
Balance is my guess. It could be slightly out of round. I've had that happen before.
Old Mar 23, 2006 | 07:38 PM
Notstock's Avatar
Welcome to the forums,
balance is one thing, but with the computerized balance machine it is pretty hard to screw up unless the fool is adding to much weight on one side and then more on the other to compensate. If this is the case you will have a lot of wheel weights on the rim.
More likely it is not aligned with the front. There are few ways to check but they are noit so easy unless you have the right tools. By no way an I implying that you don’t have the tools or the skill to do it though.
Best bet is to return too the tire shop and explain your problem. Have them check the alignment.
Let us know.
BTW here that qualifier is a dam nice tire and nice avater!
Old Mar 23, 2006 | 08:14 PM
MAD KAW's Avatar
ya the balance might be off.... but welcome to the forum.... post some pics of your bike when you have the chance..... good luck with the tire thing...
Old Mar 23, 2006 | 09:05 PM
Thanks for the advice! I will go do that today. I was afraid my tire was going to fall off or something when I was riding!
I posted pix in the NEW MEMBERS forum. Check em out if you want.
Old Mar 24, 2006 | 06:28 AM
evil636's Avatar
Knee Dragging Pimp
you can also try running it while its up on stands and you can see whats going on. if the tires out of round, youll knotice it right away. what tire place did you take it to ?
Old Mar 24, 2006 | 07:37 PM
ALLLL FIXED!!!! The tire had a flat spot...it was defective! So now I have to start over with the 100 miles on a new tire hahah
Thanks for your suggestions though!
Old Mar 24, 2006 | 08:49 PM
evil636's Avatar
Knee Dragging Pimp
scrub it in with a sander
Old Mar 25, 2006 | 10:57 PM
lemac's Avatar
wheres the fun in that.... lol I did the same to mine sanded the edges where it hardly meets the road.
