starting problem
Old Sep 3, 2009 | 02:44 AM
Rob636's Avatar
Default starting problem
I have a 04 636 and and here for the past couple of weeks my bike wont start if i have it in gear it will only start if i have it in neutral.
Any ideas...Thanks Rob
Old Sep 3, 2009 | 02:48 AM
Zbike's Avatar
Will it start with the clutch pulled in?
Old Sep 3, 2009 | 03:02 AM
^+1 to that. If not, then it is time for some switch checks.
Old Sep 3, 2009 | 03:18 AM
95451's Avatar
Welcome To K.F.
Old Sep 3, 2009 | 12:24 PM
Rob636's Avatar
No I use to be able to pull in the clutch and start it in gear but now it wont for some reason.
Old Sep 3, 2009 | 08:52 PM
check your starter lockout switch on the bar. Does not sound like it is making good contact.
Old Sep 3, 2009 | 11:43 PM
Rob636's Avatar
[QUOTE=Dragone#19;392713]check your starter lockout switch on the bar. Does not sound like it is making good contact.[/QUO
Ok I will check that out, some one else told me to to check the clutch switch to but i have no idea where it is.
Old Sep 4, 2009 | 01:01 AM
well, I normally call it the clutch switch personnally, but the proper term is the starter lockout according to the manual.
Old Sep 4, 2009 | 11:55 AM
williamr's Avatar
It's a microswitch set into the clutch lever.
Rob
Old Sep 4, 2009 | 12:36 PM
Rob636's Avatar
Rob
Ok i will check that out,thanks for your help.
