rickman 900
Old Jul 16, 2008 | 12:44 AM
39stude's Avatar
Default rickman 900
I am running a compression check on 75 rickman kawasaki 900 and just wondering if anyone can tell me what compression I should be reading on the gauge.Rright now it reads as follows #1 100psi #2 60psi #3 85psi #4 90psi. Any help would be greatly appreciated. thanks.
Old Jul 16, 2008 | 04:45 AM
BigRig18Wheeler's Avatar
Default RE: rickman 900
Welcome to the forums....
I couldn't tell you the "factory specs" on that thing....But there is too much variance between cylinders. Especially number2. If all 4 cylinders were pounding out 100, I would say good enough. Did you do compression check wet or dry? Have you down a leak down test? Have you checked timing? Valves?
Old Jul 17, 2008 | 01:27 AM
Welcome to KF. As mentioned, 20 or more psig loss/difference is not good.
Rob Ecob
Jul 25, 2012 02:05 AM
wicked900eliminator
Aug 6, 2006 06:37 AM
900A2
Jul 23, 2006 04:13 AM
sasha
May 8, 2006 09:11 PM
seats
Mar 30, 2006 03:37 AM
