problem shifting
Old Nov 3, 2005 | 07:21 PM
jeck's Avatar
Default problem shifting
I have an 86' Ninja 600.
I can shift into 1st, but not into 2nd or above.
I took off the shift cover, and everything looks fine (per the chilton manual)
It seems that when I try to shift into 2nd, it will go in(neutral light goes out), but it won't latch.
It stays latched in 1st just fine.
WTF?
Old Nov 3, 2005 | 08:22 PM
MIPLAYSTATION's Avatar
Default RE: problem shifting
Check the gear selector/shifter placement .. Could be misalighned not allowing proper upshift !
Old Nov 3, 2005 | 09:40 PM
jeck's Avatar
How do I check that?
Old Nov 3, 2005 | 10:12 PM
Guessing at this ... Set it in the neutral pos. Pull the lever off ,rest it level or just down from level to the foot peg , then ckeck the racheting action... You should have a little more upshift motion ...Try it I had an old VFR1000 intercepter have a similar problem...
Old Nov 3, 2005 | 11:53 PM
jeck's Avatar
ok-
I pulled the shifter off and tried a bunch of different positions with no help.
As I said earlier, all of the shifter parts look good. Both prawls are held to the drum by the spring. The drum looks okay.
Could this be caused by the shifter detent?
Thanks for any help
Old Nov 4, 2005 | 04:38 AM
Notstock's Avatar
Not much help here bro but have you thought about the trany?
Old Nov 4, 2005 | 04:48 AM
jeck's Avatar
Of course, but I'd rather not tear the bike that far apart if someone has a better idea.
That's why I'm on the forum.
Know what I mean?
Old Nov 4, 2005 | 04:58 AM
Notstock's Avatar
I here ya bro, hope you do not have to but I think your going to be heading there.
Old Nov 4, 2005 | 11:52 AM
Hey it was a try .. Sorry if that didn't work for ya ..
Sounds like your trans is crappin out on ya !!!
ernieb
Jun 21, 2011 02:44 AM
kschneb
Sep 26, 2009 01:26 AM
reaganshep
Apr 25, 2008 03:26 AM
Thomas
Jul 12, 2006 12:12 AM
bobsZL
Dec 28, 2005 03:49 PM
