problem with rebuild
Old Feb 7, 2008 | 03:00 AM
yellowkow7's Avatar
Default problem with rebuild
hey everybody ive been working on my zx7 for some time now, i blew the head gasket, so i pulled the engine and replaced it, got the valves relapped, reseated, etc cleaned the carbs and just about completely finished rebuilding. I cranked it, not to try to start it or anything, just to see if i had compression, and that everything was working, but it isn't. the starter motor cranks, buti get no compression readings. its like the crankshaft or cams aren't turning. i did not mess with anything below the head, and i thought i had put everything back together correctly, does anyone have any ideas off the bat on what i maybe did wrong? or forgot to do? thanks for any help
Old Feb 7, 2008 | 03:09 AM
Default RE: problem with rebuild
You put the cams in correctly?
Old Feb 7, 2008 | 03:22 AM
yellowkow7's Avatar
i believe i did i did it according to my hanes manual specs, would that cause it to not turn at all? if say i incorrectly installed them?
Old Feb 7, 2008 | 03:27 AM
If the cams are not placed correctly, a valve is stuck open, the CCT is not set right can cause a lack of pressure. Do a leak down test and double check
Old Feb 7, 2008 | 03:39 AM
yellowkow7's Avatar
i have zero pressure at all its almost like the cylinders are not rotating. what is a leak down test?
Old Feb 7, 2008 | 03:47 AM
With the valves closed on a cylinder, pressure it with compressed air, see if the cylinder holds the pressure (reading your gauge). Just the reverse of a compression test basically. I still think that you have the cams in wrong. First thought anyways
Old Feb 7, 2008 | 03:50 AM
yellowkow7's Avatar
ok im gonna try to do the cams again tomorrow, how should they sit before i bolt down the cage? should they be flush? or should they stick up a little and require pressure to bolt the cage down?
Old Feb 7, 2008 | 03:58 AM
mmi86's Avatar
Make sure you have shrader valve in the compresstion gauge.
Old Feb 7, 2008 | 03:59 AM
ORIGINAL: mmi86
hmm, a good basic thought there mmi86. To double check your tools first
Old Feb 7, 2008 | 04:07 AM
yellowkow7's Avatar
i used the same valve as i did when i first compression tested it, and i got results the first timeso im pretty sure i used the right valve.
bajus22
Apr 4, 2013 10:16 AM
dogdragon
Dec 3, 2006 04:07 PM
1991ZX600R
Nov 23, 2006 08:40 PM
indix1
Nov 6, 2006 05:59 AM
walight01
Aug 16, 2006 06:27 AM
