power commander help
Old Sep 5, 2005 | 10:15 PM
fender780's Avatar
Default power commander help
hello everyone i installed a powercommander 3 usb on my 03 zx 6rr i have a micron slipon exhaust so after i put the pc3 on my 6 the fuel injection light on my cluster is on has anyone had this happen or know why it would come on. i even remapped it with the micron map and the light is still on thanks for your help
mike
Old Sep 7, 2005 | 06:36 AM
iownarocket's Avatar
Default RE: power commander help
double check your ground ,also unplug it power comander and put bike back to normal (with out comander ) and see if that helps ,could also try hook up power comander unplug battery for tem sec then hook back up and see what it does ,all else fails power comander is either bad or you have a bad map in it .hope this helps.
gixxermickey
Jun 29, 2009 03:39 PM
arrowwhead
Jan 19, 2006 01:31 AM
arrowwhead
Jan 8, 2006 05:56 PM
eztalking
Sep 23, 2005 11:11 PM
ntence
Apr 16, 2005 03:03 AM
