Oil cooler 05 ZX-6RR
Old Oct 22, 2007 | 05:17 PM
booboo13's Avatar
Default Oil cooler 05 ZX-6RR
Anyone heard of the oil cooler on this bike breaking? It is leaking oil.
Thanks,
Chris
Old Oct 22, 2007 | 05:21 PM
markmeinteil's Avatar
Default RE: Oil cooler 05 ZX-6RR
Are you sure it's not just a bad line seal?
Old Oct 22, 2007 | 05:31 PM
booboo13's Avatar
Yea, my mechanic is telling me this. It doesn't leak that bad unless it is being revved high. I guess I should have put this under the Ninja part of these forums. Not used to the layout of this site.
Old Oct 22, 2007 | 05:37 PM
More people will see your tech message in general tech anyway.
I doubt this is a common problem. Likely, if the cooler has soldering points, it is leaking from a broken solder. Otherwise corrosion probably has caused a leak somewhere. Replacing the cooler should be a snap though.
Old Oct 23, 2007 | 03:23 AM
Where is it leaking?
edit: the approximate location?
Old Oct 23, 2007 | 05:45 AM
booboo13's Avatar
The bike isn't with me right now. Replacing it is not hard. Just super f-ing expensive.
Old Oct 23, 2007 | 05:52 AM
Was just curious as to where the leak was.
Old Oct 23, 2007 | 09:06 PM
booboo13's Avatar
The area behind the mounting flang on the outside. There is a seam between the flange and the cooler that is leaking under load.
Old Oct 24, 2007 | 04:07 AM
So the 671 seal? Just get the o'ring if I am understanding you correctly.
Old Oct 31, 2007 | 01:37 AM
booboo13's Avatar
Nope, the seal was fine. Outside the cooler so basically the cooler itself was broken. I think it was defective but $125 for a used one fixed my problem so I am happy.
VitaminE
Jul 6, 2008 04:36 AM
50 Slider
Jun 5, 2008 04:23 AM
blane10
Classic Sportbikes
Mar 2, 2008 08:25 PM
chris636
Nov 3, 2007 01:44 PM
puddin
Jul 22, 2007 01:51 AM
