In need of Carb help for an 85 Ninja 600R
Old Nov 21, 2005 | 05:52 PM
Kais3rboy's Avatar
Default In need of Carb help for an 85 Ninja 600R
Hello everyone, I'm new here. I'm a newbie driver as well. Got my license in Sept. this year and put 1K seat miles this season.
I got my hands on a 1985 Ninja 600R, I have been lookin for specs on this and can't find it anywhere. It starts right up, it's got an aftermarket pipe and K&N pods, the owner said it has a jet kit installed. Now here's the problem
When Start it, it's fine but I can't give it any throttle coz it dies out. When it's warmed up it accels, runs smooth till about 6K but then boggs or starves and doesn't want to go. If I feather the throttle it will not bog, it will run smooth. I've taken the carb apart, it looks clean no varnish deposits. It doesn't have a fuel pump, which I found interesting, The petcock has a vac input and has RES, ON, PRI. Is this problem because of the wrong size main Jet installed or is there other stuff I should be looking at?
Thanks in advance.
Old Dec 8, 2005 | 04:50 PM
86ninja600rider's Avatar
Default RE: In need of Carb help for an 85 Ninja 600R
maybe your carbs are out of sync. try that th etool is around 75$ or a shop can do it for around 50$
Old Jan 7, 2006 | 08:09 AM
Fattkaw's Avatar
Does it have a fuel filter?
Fattkaw
chill2112
Jul 28, 2009 02:09 AM
jsnider1970
Apr 12, 2008 09:38 PM
anthony330924
Aug 25, 2007 04:00 PM
joecool
May 22, 2007 12:12 AM
lotsaboost
Aug 5, 2006 03:44 AM
