Mystery red wire with a fuse in it
See on the last post that 3rd picture is where the wire is connected to the gas tank, it then leads to the plastic cap which i think connects all the grounds together and leads to the ground connected to the negative terminal.
connects the grounds to a base metal. If the base metal/wire is not making good contact, yes you may have issues. (grounding issue)
i think it is makung good contact its just the fack that there is a fuse on a ground wire, i think saturday im gona re wire it myself what gauge wire should i use and also should i replace the plastic cap connecting the grounds together?
What about where the 4 wires connect to the plastic cap?
On the first set of pics you uploaded the second one, that plastic pice the red wire runs to has 3 other wires going to it, one being the ground that goes to the negative battery, what if i want to replace that too?
