kz750 1980 fork pressure
Welcome to KF
I do not have a 750 manual. But, the kz550 shows 7.5-10psig where as the Kz1000 is showing 4.3psi-5. ( Do not check the pressures with the weight on the front wheel. Jack up the front wheel first.) I will do some more looking up the 750 specs. Good luck. Do not go over 10psig. I would prolly start at 5-7psig depending on the oil in the forks and your body weight.
