KLX250S Enricher Starter Jet Drilling
Old Jul 31, 2019 | 12:45 AM
Sforeaker's Avatar
Default KLX250S Enricher Starter Jet Drilling
I am trying to find the .018" / #77 drill bit that is long enough to fit down the enricher/starter jet hole to drill out the jet.
5 questions :
How long of a drill bit do I need?
How long does the cutting portion (versus overall length of shafts and cutting part) need to be?
Where did you buy your proper length bit?
What did you use to hold the drill bit?
Did you actually spin the bit, or more bore (up and down motion) the new hole?
Thanks!
Old Jul 31, 2019 | 12:51 PM
You are looking at the wrong part. Look in the files I have linked in my signature below. It is some of DPippin's work that I copied and actually it is linked directly to his page in the title. The jet is easily accessed and should be hand drilled with a pin vise to avoid damage. If you aren't sure exactly what you are doing you should not do it.
This is a pin vise drill and can be bought at hobby shop stores and Amazon.
You put in the drill hold the tool with your middle finger and thumb with your index finger on the top swivel, twist with your finger and thumb to drill. Put some grease on the drill so as to hold the small chips when it cuts. Be gentle very little force is needed. This is a delicate job.
Old Jul 31, 2019 | 02:32 PM
To add to ^ above,
Yes....it is a delicate job. You'll be making the orifice just a tiny bit larger and will only need to drill through, IIRC, about 1 to 2 mm of material. I picked up my bit and pin vice from a local hobby store. The cheap 10 bits for 10 bucks from amazon and ebay have been notorious for being of poor quality and questionable diameters.
Old Jul 31, 2019 | 04:15 PM
Sforeaker's Avatar
Default Thanks, yet no links?
Thank you both for your reply. KLX678, I do not see your signature or links. would you put them in the body of a reply message please.
Also, when you say I'm looking at the wrong part, what part are you referring to, and where is the part you speak of?
Thanks
Old Jul 31, 2019 | 05:37 PM
It's this link from his cheap mods link, I do think: Carb Mods Continued
See hard starting problems towards the bottom. He suggested going to 0.020". But most of us here have done 0.018" with good success.
Old Aug 1, 2019 | 12:01 AM
Yeah, I only copied his work because we need to start sharing so if someone lets their web service expire the information is somewhere else. Planet KLX went down and everything was lost.
Old Aug 1, 2019 | 01:42 PM
Sforeaker's Avatar
Default Perfect DIY Instructions
Those are incredible instructions and info. Thank you both!
Hopefully this will solve my problem.
mitch_thepcman
Jan 10, 2023 12:24 PM
buerkletucson
Mar 6, 2013 04:32 AM
kendall_smith
Apr 7, 2012 12:55 AM
Stashu
Nov 11, 2011 06:57 PM
seth6025
Dec 20, 2010 06:39 PM
