Ke100 troubles
Old Mar 15, 2009 | 06:36 AM
Skateandscoot's Avatar
Default Ke100 troubles
So i recently aquired a 1992 kawasaki ke100. I had trouble getting it running but finally got it to ride. Now here comes the weird part, I was riding it yesterday and there was a fire coming from the carb mouth. I immediately pulled over damped the flame. Since then i haven't been able to even get it to idle. Everytime i try, flames or smoke just comes from the carb mouth area. I have read up on timing adn i think that is the cause. Can anybody offer some advise on how to time a dirtbike?
Old Mar 15, 2009 | 07:28 PM
No air filter to the carb and you had flames coming out of the carb? Any other history on the ke? Was the original engine tore apart to make you think that the timing is an issue?
Welcome to KF
edit: Please vote https://www.kawasakiforums.com/forum...ad.php?t=27221
Old Mar 16, 2009 | 02:45 AM
I took the head off and the other half of the crank case but didnt go any further than that. Could that have caused a timing issue??
Old Mar 16, 2009 | 02:51 AM
You took the engine apart. So yes, check the timing, compression, etc
Your manual will help.
Old Mar 16, 2009 | 01:31 PM
How exactly do i go about checking the timing. If the timing is bad how do i fix it?
Old Mar 16, 2009 | 10:44 PM
bookmark
Old Mar 16, 2009 | 11:17 PM
ok, am back. Here is a couple of scanned pages from my KE250 manual. (1976 era) Hope this helps.
Old Mar 19, 2009 | 07:28 PM
Your amazing. It turns out the stator was loose, so i tightened it up. Thank you soo fricken much. www.Kawasakiforums.com 4 life
Old Mar 19, 2009 | 11:45 PM
Right on, glad to be of help and congrats on the fix.
Old Mar 20, 2009 | 09:10 AM
BigRig18Wheeler's Avatar
Nice work Drag!!! scanned pages are awesome! Glad you got er fixed Skate.
