Kawasaki Ninja 250r 2008 EX250K (EU EFI) - stalling, hunting idle, hard to start - no
Hi all,
Just bought a 2008 Kawasaki Ninja 250R, EU model (EX250K8F, so the EFI/DFI variant — Keihin TTK28 throttle bodies). Looking for input on a starting and idle issue before I dive deeper.
Bike info:
Symptoms:
Before I dump what I've already tried — based on these symptoms alone, what's your gut reaction? Would love to hear what experienced 250R folks suspect before I bias the conversation with my own theories.
Important context: Seller rode it to me on delivery day (so it was already warm when I test rode it) and it ran fine during the test ride. Two days later, cold start from my garage — all the issues showed up.
What I've tried so far:
So I'm reading this as: probably mechanical, not electronic. But I'm also not 100% sure I did the self-diagnosis correctly — getting literally no response at all seems odd.
My planned next steps:
Specific questions:
Thanks in advance — appreciate any input!
Bike info:
- 2008 EX250K8F (EU EFI version)
- 31,500 km / 19,600 miles
- Bought used 5 days ago
- Previous owner said it hadn't been serviced for ~2 years, didn't know when the owner before him serviced it
- Sat for periods between rides per the owner. Had been sitting in winter storage until a couple of days ago when he drove it to my house.
Symptoms:
- Hard cold start — multiple cranking attempts needed
- When it does fire, it dies almost immediately unless I keep the throttle slightly open
- Idle hunts wildly between ~500 and ~3000 rpm, never really settles
- Dies on its own at stops or after a short time at idle
- Once warm and if it is held revving, it runs (haven't pushed it hard yet)
- Read the service manual self-diagnosis procedure
- Located the Y/BK self-diagnosis terminal under the seat
- Removed the dummy plug
- Grounded the terminal to battery (–) with a wire
- Tried both Dealer Mode 1 (current faults) and Mode 2 (history)
- No response from FI indicator at all — no codes, no constant light, nothing
- FI lamp does behave normally at ignition ON (lights briefly, goes out)
- Fuel pump prime is audible at ignition ON
- Full basic service: oil + filter (HF401), spark plugs (NGK CR8E x2), air filter (HFA2505)
- Throttle body cleaning with carb cleaner
- Vacuum leak test around intake boots (spray cleaner around intake while idling)
- New fuel, in case the gas is old
- Brake fluid and coolant change while I'm at it (overdue)
- Then re-evaluate
Specific questions:
- Does this sound right as a starting plan, or am I missing something obvious?
- Any common gotchas on the K-variant specifically? (Lots of J-variant advice online, K is harder to find)
- Was I doing the self-diagnosis procedure correctly? Anything I might be doing wrong since I got no response at all?
- Subthrottle valve actuator / IACV issues — these symptoms seem to match, but I have no codes to confirm. Worth focusing there?
