Kawasaki Mule 4000 Front hub shaft too long?
Old May 21, 2021 | 08:42 AM
Ian Sinclair's Avatar
Default Kawasaki Mule 4000 Front hub shaft too long?
First of all thank you for allowing me to join your Forum I hope you can shine some light on this problem, I have a Mule 4000 2020 model and I noticed a clicking noise from front hubs when turning. I removed front wheels and found that although hub nuts were tight I could pull and push the front brake drums approximately 1/4 "
I removed hub nut and found that the shaft splines were actually protruding out past the drum centre as if either the shaft was too long or there was a spacer missing not allowing the nut and washer to secure the drum to the shaft correctly. The Mule has done 500 hrs and I have had the Mule since new from the factory, the hubs have never been removed so I am actually wondering what is going on. Any advice would help. Thank you,
Ian
Old May 25, 2021 | 03:00 AM
Welcome to kf
I am not a Mule expert.
Hit up your maintenance manual. In which you have seemed to have done already apparently.
Sounds like your bearings took a dump.
graeme quensell
Jun 26, 2022 03:20 AM
Ian Sinclair
Jun 26, 2022 03:19 AM
TRazzo
Jul 10, 2020 02:19 AM
mrbailey959
Sep 17, 2019 04:31 PM
Moose08
May 11, 2010 01:52 AM
