kawa 650 klr starting bad
Old Dec 13, 2010 | 09:24 AM
kawa 650's Avatar
Angry kawa 650 klr starting bad
Hallo, my name is Willem and new in this forum.
I have a Kawa 650 klr and every time for the first he/she starting bad.
Now I have found out that the ignition plug spark very weak (sorry my englisch is very bad) I have changed the plug for a new, no spectaculair resultat, the battery likes in good condition. When the motor is warming up, he starts perfect.
What can I do for repait this problem ?
Old Dec 15, 2010 | 09:27 AM
welcome to KF Am I understanding this correctly? When warm, the engine fires up nice, but when cold it does not fire up properly?
Old Dec 19, 2010 | 06:32 PM
jeffzx9's Avatar
(Sounds like a choke issue.)
Welcome to the forums, Kawa!! Give us more details, and we'll try to help.
Old Dec 20, 2010 | 09:54 AM
kawa 650's Avatar
The motor stay in Cabo Verde, it means here is never cold 25-30 degrees. But by the first start no choke no running, then little choke or more....and after several times finally running. Then not any problem more, I heared kawa 650 are bad starters ore not?
Old Dec 22, 2010 | 05:16 AM
Even at 77 degrees F outdoor ambient temp, on a cold start, use the choke. It is starting up for you it seems after you start using the choke.
Old Dec 24, 2010 | 02:10 PM
kawa 650's Avatar
Now I found out the battery charged fully, started w/o choke, no any problems. I think after a period no running ore starting, the battery loose energy for good fires up nice.
Old Dec 25, 2010 | 01:12 PM
Congrats on the solution. Verify that your ground connections are clean and tight and that the battery fluid levels are correct.
86chev6bt
Jul 21, 2010 07:53 PM
konacoiler
May 5, 2006 06:11 PM
deej
Apr 2, 2006 10:46 PM
macdaddy
Feb 25, 2006 07:22 AM
okie
Apr 10, 2005 11:32 AM
