Idle Adjustment
Old Mar 22, 2009 | 07:48 PM
zachv17's Avatar
Default Idle Adjustment
Hey guys I am a newbie to working on bikes. Cars anything else I can tear apart and build but anyways.. My 06 zx10r has a high idle at 3k rpms. when warm.. When warming up it idles perfect. So i am wondering what I need to do to adjust it? where is the screw? is it adjustable without taking gas tank off or is it reachable?
Old Mar 23, 2009 | 02:33 AM
There is a black knurled plastic **** on a cable on the left side of the ride under the frame.
Old Mar 23, 2009 | 02:35 AM
It will tell you in the periodic maintenance section of your manual. Although I am not quite sure when you say it idles perfect when cold but not when warmed up. Check out the pdf manuals here in KF if you do not have one.
Old Mar 23, 2009 | 04:28 PM
zachv17's Avatar
When i first start the bike up it idles at 1800rpms untill it comes up to temperature at 105 degrees then the idle jumps right up. I dont have my manual so I will try to find it on here
Old Mar 24, 2009 | 01:43 AM
I have not come across that issue before, and I have not seen any ECU recalls yet either. (not that I have looked for it recently)
Old Mar 24, 2009 | 01:55 PM
zachv17's Avatar
Right and whats weird about it is it didnt gradually happen. I was riding one day was fine. came to a stop light and the idle jumped right up and from that point on it was like that. If you roll the throttle forward ever so slightly like a mm it idles at 1500 like it always have. weird
Old Mar 24, 2009 | 11:28 PM
hmm, again I am not sure, but the sub throttle has caused a few peoples issues. Mainly due to the owner removing it and reinstalling I believe it was. You may want to check that one out. But then again a vacuum leak will cause headaches.
Old Apr 3, 2009 | 01:05 AM
zachv17's Avatar
tried adjusting the **** that did not a thing.. wouldnt a vacume leak cause perfomance iissues? it still runs like a raped ape. iv checked for leaks could not find anything
Old Apr 23, 2009 | 02:41 AM
zachv17's Avatar
Would a bad throtle positioning sensor cause this? or any other suggestions?
gc1982
Ninja ZX-9R
May 18, 2014 02:17 AM
ghunter
Mar 17, 2010 06:39 AM
BassTeQ
Apr 9, 2009 06:24 AM
Buzz363
Jun 12, 2008 06:15 AM
hoedogg
Ninja ZX-10R
Aug 29, 2006 01:48 AM
