I have a question?
I have a 2005 Kawasaki klx 125L, I have only had it for about a year now. I pulled it out of my shed, and I havent ran it in about a month. When I hit on the throttle in neutral it runs fine, but when im in 2nd gear and above, it bogs out. I checked the spark plug, the air filter, changed the gas tofresh gas (gas might have been old). How can I solve my proplem without it bogging when I ride.
ORIGINAL: firstninjabike
it has to have a fuel filter, a damn lawn mower has a fuel filter
other than that most smaller/simpler bikes dont have one at all unless it has been added
Did you check the vacuum lines (if it has any)? a cracked, or removed vacuum line could cause that. The engine not advancing through the rpms under load would cause that also.
Good ideas to throw around. All petcocks have a screen, I still placed an in line filter. Yup cracked rubbers is another thing to consider with your ride.
