Got neutral?
Old Oct 17, 2011 | 02:43 AM
Southpaw's Avatar
Default Got neutral?
My engines running strong now but I noticed that once I put my bike into gear while running I can't put it back into neutral unless I cut the engine off, then put it into neutral, then re start the engine. Any suggestions for a fix? I replaced the clutch cable and I have new clutch springs coming in the mail soon. Gonna check the thickness of the friction plates and warppage.
Old Oct 19, 2011 | 02:50 AM
Clutch adjustment and/or oil from my experience
Old Oct 19, 2011 | 03:23 PM
Also you can sometimes on bikes just give it a slight tap or let the clutch out a little.
Old Nov 25, 2011 | 11:56 PM
Southpaw's Avatar
Thank you both for your advice. I changed the oil and filter, cleaned up the clutch and replaced the old clutch springs with new ones. It took care of two problems that I was having, one being the neutral problem and secondly the bike would pull forward a bit when I put it into 1st even with the clutch all the way in but now it doesn't do that! Sweetness!!
Old Nov 29, 2011 | 01:30 AM
right on southpaw, congrats on the fix
kidritalin
Sep 11, 2007 02:30 AM
murphmaster5
Jul 21, 2007 01:50 AM
xrider
Sep 8, 2006 07:05 AM
Jutboy
Feb 16, 2006 02:39 AM
Funkdock
Jan 1, 2006 06:39 AM
