engine braking
Old Feb 6, 2008 | 12:52 AM
ezrollin's Avatar
Default engine braking
Is it bad?
If you engine brake at high rpms will it cause it to throw a rod or bend a rod?
ya know... whats the worst that could happen?
thanks
Old Feb 6, 2008 | 12:54 AM
Compstall's Avatar
Default RE: engine braking
Get up to around, ohh, 120-130 mph, click'er on down to 1st gear, drop the clutch handle out and report back to us.
Old Feb 6, 2008 | 02:04 AM
ezrollin's Avatar
yea um dont think I'll be doing that anytime soon.
I realize its a stupid question
all engine braking = bad
just wondered if you all had anything to share
Old Feb 6, 2008 | 02:10 AM
I know that I use engine braking. Maybe the slipper clutch on the 7 helps out, but started out as a track ride from the dealer for me. although going from 11k rpm, downshift 3, I have not had any issues.
Old Feb 6, 2008 | 03:33 AM
mmi86's Avatar
Compstall, im pretty sure it would be a heck of a ride but as Drag said the slipper would play a nice part in this. other than being a super sick noise imo i cant see anything wrong with this
Old Feb 6, 2008 | 02:02 PM
Kohburn's Avatar
nothing wrong with engine braking as long as you don't go overboard and drop the gearing down too far. doing that can skid the rear wheel or evn worse damage the engine internals.
Old Feb 6, 2008 | 02:39 PM
zzrick's Avatar
I was taught years ago that it was okay if done correctly, if you a mashing gears and going overboard than it could f up the transmission, and brake pads are much cheaper than transmissions. That said, I do it constantly and haven't had any problems. I think common snese is the key, just like everything else in motorcycling.
Old Feb 6, 2008 | 02:53 PM
kawi750r's Avatar
i've done it in everything really, as a mechanic kinda guy it don't feel good but i know it won't hurt anything if done right. just don't get crazy and you'll be fine, i do it all the time on my bike as a choice method. i don't have any certain rpms cuz i don't use my tach much....i ride and drive by "feel" if that makes sense.
some of the older guys prolly know what i'm talking about
Old Feb 6, 2008 | 03:03 PM
Kohburn's Avatar
i do the same. i usually keep the engine braking to the middle of the rpm range, nothing real high end unless i just shot up there in the same gear i am draggin it down in.
engine breaking when done properly is no harder on the bike/car than accelerating
OKCMULE
Jan 9, 2018 09:27 AM
Israel-klx250s
Mar 4, 2012 08:33 AM
rkutzner
Jan 2, 2008 01:55 PM
mballon
Aug 17, 2007 12:24 AM
Jit
Nov 6, 2005 10:30 AM
