coolant leak
Old Aug 26, 2008 | 12:41 AM
stretch71's Avatar
Default coolant leak
hello all I have a 04 1500 valcun nomad and its just out of warrenty with alittle over 11k on it and now I can smell antifreeze but am unable to locate where it is coming from so if anyone has any suggestions or advice for me please drop me a line .
Old Aug 26, 2008 | 02:36 AM
BigRig18Wheeler's Avatar
Welcome to the forums.
That's a tuff one without actually seeing the bike, etc.... They do make a dye that goes in the cooling system and uses ultraviolet light to detect a small leak that's hard to see with the eye. Have you checked all clamps, connections, etc?
Old Aug 26, 2008 | 07:27 PM
RonInFla's Avatar
First off, you gotta look for it!!!
Coolant leaves a residue when it drys, so, look for green stains.
Coolant fill is under the tank, and can be reached by taking the speedo off the tank (that bottom allen screw holds it on). You may have a bad fill cap. But if that's so, the coolant would be on the front cylinder head.
Check the hoses going to the coolant bottle (located behind the left chrome cover behind the engine). sometimes they'll come off or have a crack, allowing coolant to leak.
Also, god forbid, if there's no coolant in the system, what you smell is the pressure build-up seeping off. The cooling system will build up pressure like a car does when it overheats, then the pressure is pushed to the overflow bottle (which is empty) and escapes thru the bottles overfill tube.
407guy
Oct 10, 2023 01:42 AM
Derosian
Ninja 250R
Feb 6, 2008 09:20 PM
sgtpeppr
Jul 22, 2005 08:08 PM
asenft
Jul 4, 2005 09:43 PM
