changing plugs on a 05 636
My 636 plugs seem very tight in there.
I was looking for a service manual to take them out because if i finally get them out i dont want to damage anything.
Can i just work at them to get them out?
Or is there a certain way should be pulled?
Its a 2005 ninja 636
thanks everyone!
thanks everyone!
RE: changing plugs on a 05 636
Im gonna email the page out of the service manual asap. Its not on this computer. so just hold on to your spark plug tool lol You will have it by tonight, unless someone else beats me to it.
stuff i found
Maintenance Procedure
•Measure the gap
[A] with a wire-type thickness gauge.
If the gap is incorrect, carefully bend the side electrode
[B] with a suitable tool to obtain the correct gap.
Spark Plug Gap : 0.7 ∼ 0.8 mm (0.028 ∼ 0.031 in.)
CAUTION
Use only the recommended spark plugs (special
marks ). These spark plugs have special marks
[C] on the insulator, as shown. Other spark plugs
will wear prematurely.
•Measure the gap
CAUTION
•Remove the spark plug using the 16 mm (0.63 in.) plug
wrench [A] vertically.
Owner’s Tool - Spark Plug Wrench, 16 mm: 92110-1132
•Insert new spark plug in the plug hole, and finger-tighten
it first. •Using the plug wrench [A] vertically, tighten the plug.
CAUTION
The insulator of the spark plug may break if when
the wrench is inclined during tightening.
Torque - Spark Plugs: 13 N·m (1.3 kgf·m, 113 in·lb)
•Install the stick coils securely.
â—‹Be sure the stick coils are installed by pulling up it lightly.
CAUTION
yea im the one who was selling the bike. But ive decided to keep her now, i love that bike!!!! lol
Well i ended up taking changing the plugs and i did it fine with no problems. I had to take off the tank and remove the intake system.
here is a pic with the intake removed
yea the bike is green but im going to make the front part carbonfiber and basically....the bike is going to be black with carbonfiber.
Its going to be up in running (all fixed) by no later then the summer, im going to make it a project buying peice by peice
[IMG]local://upfiles/474/1B746F52450C4EF59D40D5BBD7C9B02E.jpg[/IMG]
