Chain links question
Hi everyone! This is my first post, about a technical issue.
When we say that our bike uses a 110-link chain what exactly do we count? A, B or C??
Nice to find you all here!! Thank you!
[IMG]local://upfiles/8501/E909A3AA0B2C45A3A6736BF36EE268C0.gif[/IMG]
technicly the actual "link" isB, both black tabs with the rollers C - when dealing with chains I usually consider a link to bethe BC assembly with the two gold tabs A attached. I do thisbecause number ofA and the number of B will be the same, and because you can't close the chain without the A component being there.
if its on the bike then you can count B or A - they will be the same.
if its off the bike andnot attached at the ends then make sure if it starts with a B it ends with an A, if so then count either one.(if it doesn't then it probably uses one of the special master links that don't require a chain break to attach)
hope that helps.
hope that helps.
kdick91
Jun 25, 2014 09:00 PM
